Yay! Inputtz
Ok, I'll address what I can
I watched as you removed the rads from your loop and understand the reason for it,
I also understand the heater exchange principle mentioned and I'm very aware the box alone won't be able to cool things (Could always uprate the Peltier in the box though right?)
My Pc actually seems to cool the room you know?
Small room, lots of fans, summer was nice in here lol
I'm not really for the idea of stacking the cold up overtime and only having a short Eq time to play with, I want a balanced, controllable set up where switching the Pelt on will give me xxx drop as a constant, and I'm just waiting on the fittings now, foam and sensor turned up today
The other half is at work on saturday morning and I have to clean her Pc out but thats not a big job, after that I can get onto prepping for the rebuild hehe
first up though will be getting the sensor into the box and just taking some data for ambient, maximum drop, time taken etc then I have a baseline to refer to after I add it to the loop,
The Peltier is supposed to achieve a 16'C below ambient temperature so taking into consideration that it has to cool a mass it won't be as low as that in practice,
thats aside from the fact I'm dumping heat into it, but say that with the added heat and difficulty in reaching maximum potential it can only cool to 5-10'C below ambient then thats around the mark, I can then use the heating effect to raise the temperature to above the dewpoint so the 'negative' effects of the rads adding ambient heat would actually be utilised to maintain a desired water temp,
I have a fair amount of playroom with the fans remember, all off,some on, on full or low, but first target I suppose is to make sure that the chiller can actually get me a good measure below ambient, and then go from there (If it can't I'll uprate the Tec)
I can't believe I got to the point of putting foam tubing in my Pc lol, but I'm justifying it to my Ocd cable Daemon self by aiming for that 4.6GHz, may have to 'settle' for 4.5Ghz everyday but lets wait and see, I need to remove the throttling temperature from the equation and that means a load temp of around 42-45'C,
seems wierd typing that lol, I'm almost at the point that my load temps will be other folks idle temps :O
Sorry if my ramblings are a little disjointed today and make no sense, Gf isn't too well atm and theres RL stuff all over my brain heheh
I'm confident (Read as: I KNOW I can do it
😛) I can get Sub-A cooling here, its just tweaking to find the best approach and I do have a good partner to bounce ideas off as well as you guys
Moto
