I have an asrock 2320m pro4 motherboard. I recently got a new case (nzxt h500). This comes with 2 exhaust fans which I have plugged into the 2 case fan slots of my mobo (a 3 pin and 4pin). But now I want to add an intake fan. I only have two slots on my motherboard left, one called amd header and the other rgb header. However when I plug a fan into it only works if I plug in half the pins and it makes a beeping noise. Is there any sort of splitter or hub etc I can get so I can add an intake fan or is there another way?
The fan I am trying to add is just a random stock fan from my old case (which it worked fine on but I only had 2 fans in that case)
