Recently i noticed an increase in my CPU temperature
it used to be around 36 degrees Celcius but now its constant at 44 and the smallest things send it to 50.
Browsing Firefox or Youtube used to keep it at 44 degrees
The load on my CPU also doesn't go higher than 2% when it gets warmer
My CPU is a Ryzen 9 3900XT
My CPU Cooler is a Corsair H150i Elite Capellix 360mm liquid cooler
The fans i have in my case are 7 Corsair ML120 Pro 120CFM and 2: 140mm ML140 Pro 97CFM
The case i own is a Corsair 5000D Airflow
3fans are attached to my Radiator wich is mounted to the top for exhaust
1 in the back for exhaust
3fans on the side for intake
and the 2 in the front for intake
All of my PC parts are less than a year old.
I haven't done anything weird in my BIOS and i checked for Viruses on my PC
This was from a few months ago
And this is it now
My FAN options for the 3 fans attached to the Cooler
Now what i did see was that when i go in Task Manager it says my GPU is running at 4.10 / 4.20GHZ
But im sure it should be running at 3.8ghz
I have no idea how accurate Task Manager is with it though.
If anyone wants to help out it would be much apriciated!
