Dell power supply
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Is there any way to tell from just looking at a Dell power supply whether it
is standard ATX or proprietary? If not, is there a listing somewhere? I
would hate to fry someone's motherboard.
G
Guest
Guest
I think it might be fun to fry someone's motherboard. I've never seen that -
I'll bet it makes a lot of smoke.
As for your question: Post the computer's model number and we'll let you
know.
Ted Zieglar
"William J. Lunsford" <nobody@nowhere.com> wrote in message
news:M2c9e.1595$L03.439@newssvr17.news.prodigy.com...
it
G
Guest
Guest
A while ago, someone in the know posted this sort of info in this usenet
newsgroup.
As a general rule, if you have a Pentium II or Pentium III system there, the
power connector to the motherboard is a faux-ATX. In other words, the connector
plastic looks exactly like a normal ATX connector, but the voltages delivered to
the pins differ from the ATX standard. This faux-ATX connector seems to have
had pervasive use across the older Dimension and Optiplex computers.
If a Pentium 4 system has an ATX-looking power connector and a separate 12v
connector, I'm almost dead certain that the power supply meets the ATX-P4
standard. This has certainly been my experience with Dimensions of various
sizes and the Precision 340, 350, and 360 models.
Somebody else may be able to fill you in on the more recent Dell "servers" which
are in fairly standard cases, but I'd bet that the power connector on any Dell
mid-tower P4 server is standard ATX.
I'm sure product cost has driven Dell in the direction of standard power
supplies. Like WAL*MART, Dell is good at wringing pennies out of the overall
cost of assembling and shipping its products. Now if we can just get Dell to
back off of the other non-standard motherboard connectors for cooling fan, USB,
and front panel on-off+LEDs !!! ... Ben Myers
On Tue, 19 Apr 2005 18:25:48 GMT, "William J. Lunsford" <nobody@nowhere.com>
G
Guest
Guest
Thanks for your reply, but I'm asking for future reference, not to work on a
specific system.
"Ted Zieglar" <teddyz@notmail.com> wrote in message
news:Ngc9e.110$yq7.1626240@news.sisna.com...
>that -
> know.
> Ted Zieglar
> it
G
Guest
Guest
Thanks for the information! Your help is appreciated.
Bill Lunsford
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:42654f5a.21884165@nntp.charter.net...
> newsgroup.
> the
> connector
> delivered to
> have
> 12v
> various
> which
> Dell
> overall
> to
> USB,
>>it
G
Guest
Guest
Henh. Not so much smoke, but lots of expense. I had to hook a Compaq
up to some bench supplies for charaterization once, without the
benefit of proper documentation....
G
Guest
Guest
<William P. N. Smith> wrote in message
news:rhab619knut31f0i1f8gmo57j6cqqistsf@4ax.com...
>>that -
A system board is never quite the same once you let the "magic smoke" out of
the south bridge chip.
;o)
Stew
G
Guest
Guest
Even so, when you stumble across a Dell system with power supply requirements,
"Post the computer's model number and we'll let you know", just to be on the
safe side... Ben Myers
On Tue, 19 Apr 2005 20:14:33 GMT, "William J. Lunsford" <nobody@nowhere.com>
>Bill Lunsford
>> newsgroup.
>> the
>> connector
>> delivered to
>> have
>> 12v
>> various
>> which
>> Dell
>> overall
>> to
>> USB,
>>>it
G
Guest
Guest
Standard, yes. But not ATX-12v standard. The Dimension 3000 is one of the
first systems to use the next step in the evolution of the computer chassis,
BTX. The BTX power supply connector is larger than the ATX connector. I have
yet to figure out whether the BTX connector is simply a new name applied to the
same sort of connector used in some Intel server boxes of a few years ago. In
any event, it does away with the separate 12v connector which was born during
the evolution from Pentium 3 to Pentium 4.
Like ATX, BTX is supposed to be better than ATX, which truly was an improvement
over the 1984 vintage baby-AT... Ben Myers
On Wed, 20 Apr 2005 00:06:08 +0100, Paul <removemepaul_news@dsl.pipex.com>
wrote:
>What about Dell Dimension 3000 (UK Model)Pentium 4 3.0ghz Prescott, does
>it have a standard atx power supply?
Paul
Splendid
Mar 30, 2004
5,267
Thanks for the reply.
Does this mean I will have problems replacing the mobo with an asus
p4p800-vm, which I have read will drop straight in?
G
Guest
Guest
That's just the start of potential issues fitting a non-Dell motherboard into a
Dell chassis. Other gotchas:
non-standard cable to front panel USB
non-standard 3-pin connector on fan on the back of the chassis
non-standard header for cable from motherboard to on-off switch/LEDs
power supply cannot have auxiliary external power source to attach monitor
.... Ben Myers
On Wed, 20 Apr 2005 09:33:42 +0100, Paul <removemepaul_news@dsl.pipex.com>
Paul
Splendid
Mar 30, 2004
5,267
FYI I have just installed the asus mobo with only one slight
modification. I had to discard the connector for the front panel and
just clip on the wires individually to the corresponding pins on the
mobo. The usb header was the same as the original dell mobo, the cpu
fan connector also was not a problem and the monitor is plugged into its
own power socket, not daisy chained from the pc. Now I have an AGP
slot! Thanks for your replies anyway, I guess the Dimension 3000 in the
UK is different from the one in the US.
Regards
> ... Ben Myers
G
Guest
Guest
I would bet that the Dim 3000 is the same in UK and US. There is no economic
reason for Dell to build them differently. (Possible exception: the "fused" UK
power)
None of the "gotchas" are major problems, but they do entail fussing and
fiddling around a bit. My basis for a comparison between motherboards is Dell
vs. Intel, because Dell systems use moidified standard Intel board designs.
.... Ben Myers
On Fri, 22 Apr 2005 10:49:56 +0100, Paul <removemepaul_news@dsl.pipex.com>
>Regards
>> ... Ben Myers
