[SOLVED] dual pc elgato issue
Dec 19, 2020
When I plug my elgato in via HDMI my monitor display goes black. I'm thinking it's because my pc is recognizing my elgato as the main display, but how can I fix that if my monitor is black?
The elgato has a throughput HDMI port which means you stick one HDMI from the GPU to the input side of the elgato and a second HDMI cable from the output of the elgato to the monitor and everything the gpu shows will show up on the monitor even with the elgato turned off.
Monitor goes black when I plug in elgato. I am running a dual pc setup
I think my pc is trying to use my elgato as the main display. How can I fix if the display is black?
Latest posts
