Hello!
Whenever i connect a hard drive or a USB Flash drive to one of the front panel's USB ports the drives constantly disconnect ( they disappear completely from my computer ). The system was built a year ago and it has the problem since then.Any ideas what may be causing this frustrating problem? Thanks in advance! (my case is the Fractal Design Meshify C Mini)
HWinfo System report:
Code:
CPU: AMD Ryzen 3 2200G (Raven Ridge, RV-B0)
3850 MHz (38.50x100.0) @ 3847 MHz (38.50x99.9)
Motherboard: ASRock AB350M Pro4
BIOS: P5.50, 12/20/2018
Chipset: AMD B350 (Promontory)
Memory: 16384 MBytes @ 1498 MHz, 16-17-17-36
- 8192 MB PC24000 DDR4 SDRAM - Kingston KHX3000C15D4/8GX
Graphics: AMD Radeon Vega 8 (Raven) [AMD]
AMD Radeon Vega 8, 2048 MB DDR4 SDRAM
Drive: OCZ-TRION150, 117.2 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: WDC WD5000AAKS-00A7B2, 488.4 GB, Serial ATA 3Gb/s
Drive: WDC WD10SMZW-11Y0TS0, 976.7 GB, Serial ATA 6Gb/s @ 6Gb/s <-> USB
Drive: WDC WD10JMVW-11AJGS4, 976.8 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
Sound: ATI/AMD Display HD Audio Controller
Sound: AMD Raven - Audio Processor - HD Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Network: Remote NDIS based Internet Sharing Device
OS: Microsoft Windows 10 Professional (x64) Build 18362.116
