[SOLVED] GPU Fan speed ramps up for a few seconds ?
Hey, I've noticed that sometimes my GPU Fan speed jumps from 2800 RPM (2800 is max for my GPU in Afterburner) to roughly 4000 RPM for a few seconds. I believe that this is caused by high temps, as this only happens with temperatures reaching 80 degrees Celsius when I'm stress-testing/overclocking. Is there a way to crank up my RPM even higher than what my max setting in Afterburner is?
My GPU is a AORUS GeForce RTX 2070 SUPER 8G
D
Hello, what's the exact make and Model of your current PSU, power supply unit ?? Why do you want to crank the fan RPM even further ? Is your current RIG/setup properly ventilated and cooled as well ? How many case fans do you have for proper air flow ?
80 C is a high temp value, but not alarming enough to jump on any conclusion.
Edit::
BTW, are you sure the reading is 4000 RPM ??
Do a clean re-install of the MSI AB tool, as well as your GPU drivers, and download GPU-Z to check the card's parameters under the SENSORS tab of this tool. https://www.techpowerup.com/gpuz/
Edit::
