[SOLVED] GPU Running Hotter Than Usual.
LowEndPC1234
49
My graphics card usually get 49-51c on idle, But now it gets 58-59c on idle, I cleaned my PC, The temp is still hotter than usual, I Updated the driver, Still doesn't make the temp lower. Any solutions ?
SPEC :
Intel Pentium E5700
MSI GT 710 1GB DDR3
Alcatroz 225s
ASUS P5G41C-M LX
WD Blue 500GB 7200RPM
Try cleaning off the heatsink and applying new thermal paste. Also a good idea to post some pictures of your case and fan layout. That power supply is a bit scary looks like it has a 1 yr warranty which is solidly in the junk quality level.
