https://www.bleepingcomputer.com/forums/t/707584/computer-acting-funny-after-about-20-hours/
Have been trouble shooting this for about 4 months. Have done every malware scan, ram check, check disk i can think of or have been recommended.
After 1-2 days of being on my computer begins to malfunction. Usb devices connected work, but I cannot connect anything new and if i remove and try to reconnect anything the computer doesn't recognize it at all. If the device has a light it comes on briefly but that is it, no beeps from the computer or anything.
Certain applications no longer launch, It seems anything dependent on starting a new Service fails. Simple Applications like Factorio or FTL will launch if steam is already open or using a drm free version. Steam will not launch if closed.
Device manager freezes during search for plug and play, or during uninstalling device.
If I ask the computer to reboot/shutdown through any means it will soft lock on the restart/shutdown screen with the circles rotating forever.
After a hard reset everything works 100% fine, all devices and programs run as intended and restarting/shutting isn't met with any issue.
I ran https://www.tweaking.com/content/page/windows_repair_all_in_one.html once by recommendation and for 22 days the computer was on without issue. after restart it began having the issue again, when i tried to rerun the program it froze part way through forcing a restart, upon multiple restarts the login screen was missing the login area forcing me to restore from recovery point. I have not tried again since then.
Windows 10 pro Version 1909 (OS Build 18363.592)
Asus Z87-plus
i7 4771 Haswell
Gtx 1070 8g
16gb dd3 1600 corsair
(nothing overclocked)
cooler master scout 2
Asus Z87-plus
i7 4771 Haswell
Gtx 1070 8g
