So I had been running into problems with my cpu temperature, so I took it out and cleaned it. Afterwards I realized at some point, I had bent a few pins and set them back straight and have put my cpu back and connected the cpu fan. The problem is since after this, my motherboards rgb lights are glowing when I plug the power cord back into my computer, but hitting the power button does nothing.
I have tried resetting CMOS, checking the ram to see if it was moved. Checking the CPU again to see if it’s properly on, and checking cables plugged into power supply. All seem fine but still no response when I hit the power button.
My specs: Asus Prime X570 Series motherboard, AMD Ryzen 7 2700x, gigabyte gtx 2080
EVGA Supernova 750 G2, Samsung 970 Evo SSD,
Any help is greatly appreciated. Thank you for your time reading this.
