[SOLVED] Help with overclocking my i5 7600 CPU to 4.0 GHz
Mislav_1
39
Hello there. Can someone help me with overclocking my CPU to 4.0 GHz its at stock. Anyone with good profiles?
I am using Intel Extreme Tuning Utility. These are defaults for me: http://prntscr.com/oxux4n
What should I changed and to what?
Thanks
I would also use something like hwinfo64 or CPU-Z to look at clock speeds, probably more reliable than task manager. Note that it will only go to max frequency under load. If you're limited by your GPU in games your CPU may not boost. Can look at max GPU and CPU usage while gaming to check (look at max usage on any single CPU core, not overall).
