Home wireless network upgrade... help please!
joshwood123
78
i need help, i recently bought a new router to extend and speed up my home internet connections, a Rosewill one ( here it is on newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16833166028 )
and i cant get it to connect to my quest modem, that has a WiFi antenna... if anyone has gotten this to work before, i would be very happy if you could help me, we need faster internet for work.
thanks for any help in advance
-Josh
If the existing modem/router is wireless and you are trying to connect the new router via wireless you will have problems unless they both support WDS (wireless distribution).
You should be able to extend wireless coverage by connecting the second router to the firstby ethernet cable and making certain adjustments to the routers' settings.
