Question How to get to previous system ?
I wanted to updgrade old pc with ssd. It is dell optiplex 760
intel core duo
2x2gb ram
Windows 7
I cleared the drive which gave no effect.
I cloned the system to the new plugged-in ssd for which I bought sata power y plitter. Now hdd and ssd are plugged in and ssd also is using sata cable form the disc drive.
I turned the pc off, I took out the hdd and I tried to boot the system but from now all I get is "configuring windows update" and its getting stuck on 35% or 100%
The safe mode is also stuck at that and trying to boot without ssd and back with hdd is the same.
I want to know if can even get it working back with hdd if the ssd is the issue ?
Thanks for any help!
