[SOLVED] Humming noise from speaker
nhk5
44
Recently, my PSU shorted out, and i bought a new one. My old one was a Corsair CX750M, and the new one is a Cooler Master Gold 750. After i swapped in the new PSU and booted my PC, a humming noise started coming from the speaker. I tried connecting the aux cable to the monitor, but still the hum persists. The hum doesnt come when i connect to any other device.
Any and all help is appreciated to get rid of this hum. TIA
My specs are
i7 7700k
Corsair Vengeance 32GB
Asus z270f mobo
EVGA GTX 1080ti
1.Turn the volume up and check all your cables, you will hear the interference when you find something loose.
2. Make sure everything is plugged into the same outlet.
2.You can try Snap-on Ferrite Cores on each audio cable those are good for blocking out EMI and RFI interference.
Latest posts
