Hi I recently built a desktop and with everything plugged in I get q led code 00 immediately after I press the power button. The boot, cpu, vga, dram lights are all off. All of my fans turn on and light up. The built in rgb on the motherboard cycles through colors when the psu is flipped on and turns red once I press the power button. If I remove everything except the 24 pin power connector and the cpu the same exact thing happens. The bios flashback also works. Does anyone know what might be the problem (I think it might be the cpu).
