IBM and Hipro power supply - Is it a standard ATX
I am working on an IBM workstation. The power suppply is a 185W Hipro. I am trying to figure out if it is a standard PSU. I would like to replace it with somthing larger as I think I am running the computer pretty close on available power. Looked at the calculators on the PSU FAQ post and it estimated me over my current PSU's rating .
http://www.jscustompcs.com/power_supply/
My first question:
Does IBM use proprietary connectors?
I hope to put a standard ATX PSU in this machine.
Further questions (assuming it is a standard ATX connector):
What are some good PSU options for this machine?
The computer is a IBM Netvista M42 8305
Specs:
2.53 GHZ P4 (Northwood)
768 DDR (PC2100)
Radeon 9550 (I added this)
then the usual HD, CD etc
It is running stable but I would like to add another HD, DVD burner (I have these available in another machine), possibly upgrade the video card in the future. I also have a PCI video card (Radeon 9250) that I may add to allow 2nd monitor to be used.
I was looking at NewEgg and saw a few that i thought may work well.
Does anyone have any comments on any of these?
http://www.newegg.com/Product/Product.asp?Item=N82E16817171007
http://www.newegg.com/Product/Product.asp?Item=N82E16817153006
http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
One last question:
This computer is running a weather station and will be running 24/7 do larger power supplies draw more power when the system is running at idle?
Sorry for the lengthy post, i just realized that I know less about this subject than i thought i did.
Thanks for the help
My first question:
Specs:
768 DDR (PC2100)
One last question:
Thanks for the help
