Hello,
Ok, here's what I'm trying to do:
My computer is running quite hot, so i decided to clean out the dust with compressed air. I also decided to maybe install a new fan
here's the problem:
All my 4 pin connectors are used (Graphics card ate up TWO connectors(9800GT))
I'm afraid if i connect something else to another connector i'll fry my motherboard
Once I installed a ram stick, it fried my motherboard.
Here are my questions:
1) Is compressed air the best solution to clean a PC?
2) If i install this new fan, where should i connect it to, since all my 4 pins are used up?
3) If i connect the fan and boot up my pc, will the motherboard fry?
Specs:
AMD Athlon 64X2 Live! 4600+ @ 2.41 Ghz
Nvidia GeForce 9800GT Point of View Graphics 512MB
2GB Ram (2x512 MB sticks, 1x 1GB PNY Stick)
2 Hard drives, totalling around 280GB
Vista Home Premium 32Bit
1 Cpu fan and heatsink
The computer is running fine untill now, i just wana cool it more without frying the motherboard or running out of power.
Thanks!
here's the problem:
Specs:
Thanks!
