Question Internal SATA/HDD cable for the Dynabook Satellite Pro L50-G-11H ?
Aug 20, 2024
As the title says, I'm inquiring about where I can find the internal SATA/HDD cable for my satellite pro L50-G-11H cause for the life of me I can't find it anywhere, nowhere online, not on ebay, not locally. it doesn't seem to exist anywhere, & it's driving me nuts cause now I can't even upgrade my storage which was one of the reasons I bought this laptop.
So, uh, anyone know where I could find this cable? cause at this point this is becoming hopeless.
Laptops generally don't have a 'cable'.
Rather, they have a port built in, to give both data and power to a SATA device.
OR, an NVMe port.
What is in it now?
OR, an NVMe port.
What is in it now?
So, there's this connector on the motherboard right next to the battery that you can connect a flex cable that hosts the SATA connection.
That, is missing.
(Image showcasing the specific connector on the motherboard, & how the flex cable would go & it's placement)
(Image taken from an apparent dynabook manual on how to remove the HDD that was already pre-installed on specific L50 models)
You bought this used?
Have you asked Toshiba?
-Yes, I did buy this used however from what I've found online it isn't a case of the seller taking out the SATA/HDD cable, it does genuinely seem like a lot of models just never shipped with it.
-I honestly haven't found a support email ANYWHERE so no, I have not.
