It might be a borderline case where your probability of sustenance is tentative and to an extent dependable on the condition of that unit where you might or might not just get away with it. But if I am buying such expensive hardware, will I take that chance???Yeah but with 0 oc will it be able to sustain them right?
It might just hold up, but that PSU is pretty mediocre quality. If it is still in the return period, return it and get something better from Tier A. Otherwise upgrade it as soon as you can...
[EOL] PSU Tier List rev. 14.8
PSU Tier List 4.0 rev. 14.8 (END OF LIFE) Last Update: 27-07-2021 Legend : Gray - EoL/obsolete and/or otherwise not recommended for purchase. Green - small form-factor (gold and blue colors are disregarded due to scarcity of SFX PSUs) Gold - best units in the tier (includes requirements for blue ...linustechtips.com
I won't OC with that unit.Now until I make the money to buy a new psu can I run it without OC ?
This whole system wont use more than 450w. 750-1000w is insane overkill.The simple answer is No. The 3000 series cards are HUGE power hogs and can have power draw spikes as many reviewers have found.
My personal practice is to have about 30% more power supply than what my system uses at max. Also my favored minimum rating is 80 plus gold.
750-1000w 80 plus gold would be my solid recommendation.
Assuming no overclocking on CPU and GPU then yes.
750-1000 will allow for upgrades down the road and handle any power spikes the 30 series is already known for
