[SOLVED] Is my MSI B350M pro vd-plus motherboard compatible with an RTX 2070 Super?
rwreyesbe95
Hey, kind of a noob question, but I wanted to know if these 2 were compatible. I checked on the manufacturer website and I couldn’t find it on their list, but then again I couldn’t find my current GPU either (GTX 1660) and that’s running fine in there. I also checked on pc-specs.com and I saw the 2070 and one called the 2070 SLI but I couldn’t find one called the 2070 SLI, maybe a fancy nickname for the super? fingers crossed
Yes, there wont be any issues with compatibility, the VGAs are meant to work with all boards, as long as they have the same compatible slot, which PCIe 3.0 is.
