All silliness and games aside here's what you want to implement: (use a search engine or visit any decent auction site and search for: 'superpass wifi' or 'mile wifi'. I'd give specific links but I'm not completely familiar with the protocols on Toms 2and don't want to trample any toes or get myself into trouble. You want a directional antenna, preferably one that you can easily set up as a bridge or repeater. These systems are very flexible and can be setup in just about any way you could imagine. They also vary in price from very expensive to fairly reasonable. But if you want to solve your problem then 'superpass' or something similar is what you want to do. I stay clear of the trendy/big name equipment because it can get rather proprietary and 'one way', i.e. not very flexible in how you choose to deploy and its easy to blow $$ on the wrong gear if you aren't very familiar with what you need. (One exemption to that would be 'Hawking wifi', I've accidentally found their older gear to be fairly high quality and stable, thoguh I haven't really used much of their equipment to be frank. I'm really a big fan of SUPERPASS. Whatever you choose you'll absolutely want a good directional antenna, and bigger is frequently better. Avoid no name stuff, at least until you are more familiar with what you really need. You can use these indoors but your results will be better fi you mount it outside.
