[SOLVED] Issues with MSI ARGB fans showing up in MSI Center
Apr 7, 2021
20
I just got a new case from MSI that comes with 4 ARGB fans, and I will list my specs below.
Case: MSI GUNGNIR 110R (new)
Mobo: Gigabyte B450m DS3H
GPU: Msi Armor RX 570 8 gb
CPU: Ryzen 5 2600
Ram: 32 GB Corsair RGB RT (4x8)
So, my issue is that I don't know how to integrate these fans into the computer. I plugged the 2 of the front fans into the provided 3 - 1 fan adapter, and the one exhaust fan into the third slot, since my motherboard only has one fan header. That meant two of my front fans spin and my rear exhaust fan. The fans RGB cables (I think) are already wired into a hub that is powered by a SATA, and the fans light up fine. But the issue is, I don't know how to get them to link to MSI Center. In MSI Center, I don't even see Mystic Light available as a feature set. Is that because the fans aren't connected right, or is it a software issue?
Neither. You just can't link anything to MSI Center on non-MSI motherboard. RGB made by different manufacturers usually won't work together. I mean, it will light up when powered, but you will have no control over how it lights.
