I have 6 Hard drives installed.
And yeah, i thought i was clever and just stuffed them in all willynilly.
I have programs installed on each one. Windows will show some of the programs in start some in add/remove and some i just randomly find when im going through folders (I just found a separate installation of iCue from october of 2020 and I think i'm going to have to use cmd to uninstall it- because there's no uninstaller and the updated, useful, used, and wanted version is showing up in the add/remove program/app control panel windows 10 settings.. spot. anyway that's not really the question.
the question is... does (screenshot) this look as jacked up as I think it is? and with like 2 ish terabytes of stuff installed is there any way to get windows to organize these drives while maintaining my sanity (i.e. not reinstalling everything)?
Feel free to point and laugh at me for being too lazy to understand how RAID works and why it may be useful.
Also, please help me. This mess has ended up taking a significant portion of my life away because of its sheer... mess. oh, and i've disabled indexing to make it extra obnoxious for myself.
if it matters: bootdirive is C: & the only m.2nvme
D: G: & H: are all SATA SSD ranging from 80-256Gb
E: & F: are both 1 TB HDD
E:, however, has decided to to play make-believe with me and pretends that half of it's capacity never existed.
I have no idea what happened to it but... I do know it also makes userbenchmark spaz out whevenever it does any tests on it. so.
I have no idea how or why they all have recovery and EFI partitions.
Thank you. 🙏
Thank you. 🙏
