Hello everyone, I've got a problem that's making me very anxious.
Yesterday I built my PC and after setting everything up and installing Windows I realised the cooler was installed the wrong way and was butting into the space of the RAM. I turned off the PC, unplugged the PSU and reinstalled the cooler the right way. I then started testing some games, which ran pretty good, including F-Zero GX with Dolphin. After installing the AMD Adrenalin software with the latest WQHL driver and turning on the setting enabling resolutions higher than my 1080p TV, I opened Mirror’s Edge and started testing those higher resolutions. CPU fan naturally started getting louder and the game stuttering a little, and suddenly my TV lost video signal and the fan went on full blast. I switched the computer off after a couple minutes of that, and since then, the fan is always louder than usual, even when temperatures are fine and the CPU is idle. I can’t play the same game on Dolphin without it crashing, and the C/GPU seems to underperform in games. I just reinstalled Windows and even during the installation the fan was louder than needed and the same game that used to run fine is crashing in the same spot. I played some Fortnite and I can't even get consistent 60fps, which I know is more than possible with this setup. Should I reinstall the cooler and apply more thermal paste? Is that my problem?
Thank you very much in advance. Here are my specs:
- Asrock B450M Pro4
- Ryzen 3400G, stock cooler
- Corsair LPX 8GBx2 3200 MHz
- Samsung 970 EVO 500GB
- Seasonic S12II 620W
- Yep, no discrete GPU
