Question Microphone not detected when connected to monitor
Aug 19, 2023
My headset microphone is not detected when plugged into my monitor (which is connected to my GPU via HDMI). The output works perfectly fine.
My microphone will work when I plug the headset directly into the audio/mic port in the front panel, though the monitor audio is much better, and I would prefer to not have to switch between the two constantly when doing things solo or with friends.
I have tried looking in the sound settings for the control panel -- it says that the device for my microphone is currently unplugged (when connected to the monitor), which means it isn't detected.
Monitor: LG Ultragear
GPU: NVIDIA GeForce RTX 3060 (Driver version 536.99)
Motherboard: Gigabyte B660M DS3H AX DDR4
Anyone know how I can fix this?
I was able to use this setup with my laptop -- I connected the external monitor to it with HDMI, and then plugged the headset into the monitor, and the mic worked fine. Is that different somehow?
I looked in device manager and it says "Generic Monitor (LG Ultragear)".
My monitor is an LG 24" Ultragear FHD 144Hz 1ms Gaming Monitor (24GN50W-B)
