I know this problem has been pointed out a few times, and that there isn't much of difference between x4 and x16, but it's something that really bothers me.
I tried reseating the gpu, blow the dust (compressed air), updated the bios, drivers, bios settings but nothing worked.
Specs.
R5 1600
Rx 6500 xt itx
16Gb 2400mhz
Ga-b450m-s2h rev 1.x
700W PSU
gpu-z doesn't change when using the render test (i can't insert image for some reason)
and i get same reading in the amd software.
I don't have an other pcie device installed or m.2 ssd, the gpu is installed in the correct slot (the only slot there is).
I tried running heaven benchmark and got nothing.
Power saving mode is disabled in the bios.
I can't set the x4/x8/x16 things in the bios except the generation which i set to gen 3.
please help :>
Specs.
R5 1600
Rx 6500 xt itx
16Gb 2400mhz
700W PSU
please help :>
