[SOLVED] Need hardware suggesion for 60fps gaming on 900p monitor
Jan 28, 2021
I have a 1600x900p monitor and my curren system is:
Intel Core i3 4160
gskill ripjaws 2x4gb ddr3 1600
MSI Gaming GTX 750ti 2gb gddr5
Gigabyte b85m d3h
antec vp450
corsair gaming spec 3
wd green 240gb sata ssd 2.5'
I want to play Valhala/RDR2/2077 and other upcoming games with good fps.
I don't even have a budget to consider a new monitor so i'm thinking of just upgrading the components if needed.
I was thinking of a GTX 1660 and maybe i5-10400? Of course i'll need a new motherboard and ram too.
But then I thought why not just upgrade the cpu to i7-4700k or something and get a better graphics. Will these two things better to invest in or should i get everything new?
To game at 1600 x 900.....you don't need a lot.
You could do it with the MB you have if you upgrade the CPU and the GPU.
The only thing is....the higher end CPUs that will work with this MB seem a bit on the costly side.
