Dec 8, 2024
22
7
15
Mobo: X570 Aorus Master
BIOS Version: F39d
CPU: Ryzen 9 3900x
RAM: Corsair RGB 16 x4 3200mhz DDR4
Hello, I want to install a fresh pair of Windows 11 on my PC, I used Rufus to make the bootable drive, (and formatted as GPT, UEFI, and NFTS) but when I plug the bootable USB in my motherboard, and after changing BIOS boot to the USB, my PC is booting from my SSD, where I had windows 11 installed. I disabled secure and fast boot, is there anything else I can do?
Thanks
When i did a windows re-install i read somewhere that if you hold down shift key and tap F8 whilst doing the restart you come up with different start up options , when you find the correct menu change to boot from usb and when finished dont forget to change it back , i did it and it worked , my pc is custom built so i dont know if it will work on any pc.
Latest posts
