Hey so, after rummaging through forum posts on this website with the same issue as me, I have had to result to posting as I am unable to boot my PC. And after forking out nearly £140 these past three days I really need a resolution.
TO start, the specs:
Mobo - ASUS PRIME A320M-K - new
CPU - AMD Athlon X4 Quad Core AM4 - new
CPU cooler - Cooler master hyper 212 EVO
RAM - CORSAIR Vengeance LPX DDR4 2400 MHz PC RAM - 8 GB - new
GPU (not currently installed) AMD Radeon Sapphire R7 240 ( i think) - had it a few years already
PSU - G7 Power Extreme 580W - not sure on age at least 5 years old, was installed when I bought the PC from a friend
Hard drive - Seagate Barracuda 500gb - same as PSU
I will describe to you the whole story of my week so far!
So on monday I decided to try and boot up my PC the way it was after not using it for a year (It may have had to encounter a bit of movement since last use because I moved house) and it would power on and everything, fans going etc. but would not boot. When I tried to hold down power button it did not do anything, in the end every time I have tried turning it off and on again I've had to use the switch at the back to get it off. After looking at my computer hardware I put it down to the mobo being dead (no power to mouse or any of the USB ports on start up either) I'm not sure on the make, all I know is it was an ASUS but a very old one. so after paying for a new one, and some new ram cause I wanted to make sure I had some compatible DDR4 ram for my new mobo, I went to set up. That was there I realised the CPU I had was incompatible (Being AM3 rather than AM4) even though I thought my research was inaccurate, thinking my old hard drive was an AMD athlon not an AMD FX series. Turns out I had remembered wrong. So I ordered an AMD Athlon and that arrived today. After installing everything (to what I believe would be correctly) to my new mobo, CPU and RAM, I went to boot. Same thing that was occurring on monday happened again. Lights on, fans on, power on, No video to monitor, unable to switch off my holding down the power button, just the switch at the back. The mobo seems to make a bit of a noise with the orange LED light on when I switch the wall and PSU switch on, but I don't know if that's normal. I've tried with GPU installed and without it installed.
I don't think I have one of those beepers that tells you what's wrong either. I would really love some tips though because I have spent a lot of money and I want to use my PC so badly! I have a friend or two who can have a look but for now I was hoping someone here could give me some ideas.
Could it be the hard drive? or maybe a wire from the PSU? I really don't know! It can't be the RAM or CPU as I have checked over and over for compatibility, and it just seems weird I am having the same problem after replacing the whole motherboard.
If you need any more details please ask. Thanks! please remember I am a newbie so It could just be something so simple!
