[SOLVED] PC Running Extremely Slow After Reset
keenwads
92
Hi all,
Earlier today I reset my PC in order to clean up space- my PC was running fine with no performance issues. However, after the reset the performance of the PC had significantly worsened, with random stutters and freezes every 30 seconds that last up a minute. According to the windows resource and performance monitor, The CPU, GPU, Memory and Disk ratings of my system are poor, despite me taking good care of them and them having worked perfectly before the reset. Does anyone know how to fix this? Any help would be greatly appreciated.
Specs:
i7 8700
Nvidia GTX 1060
16GB 3000MHZ DDR4 RAM
500W Gold Rated Power Supply
System is installed on a 120gb WD Green SSD
Additional 1TB Seagate Hard Drive is installed
Motherboard is an Aorus z370
I assume all Z390 have same utilities.
Go to the utility menu and install App Centre. Run it and it will check if you have latest drivers. It may also suggest utilities, many of which aren't really needed.
