Hi,
This is a fairly long problem so the following may seem a bit disjointed but try to bare with me. My computer is connected to my television and I sit on a sofa rather than at a desk, because of this I use a USB hub to connect my devices and have it next to the sofa. In total I have 4 USB devices attached to my computer.
Attached to motherboard:
1. A dongle for wireless Xbox controller
USB HUB (Connected to motherboard, mains powered)
The hub is connected to a 3 metre usb 2.0 cable which runs across the floor to the sofa where my devices plug in.
The Issue:
I've had the computer for around 2 years like this with no real problems, one day the headset microphone is picking up some kind of interference/feedback and deafens whoever I am speaking to, think the standard feedback from moving a mouse times one hundred. I try the headset connected directly to the motherboard and the issue goes away. I assume the hub has become defective to some degree, maybe it is no longer receiving mains power and is being powered solely by usb. I throw it away and order a new one of the same kind. The new hub is working fine for around 2 weeks, no audio feedback of any kind but all of a sudden all of the devices attached to it will not respond. They are receiving power as muting/unmuting the headset causes a light to turn on and off when powered, but it is not picking up any sounds from the video playing on screen, the mouse and keyboard are also not responding. The only solution is to hard reset the computer. This has happened twice so far and is incredibly annoying, I have also had the headset disconnect briefly for around 5 seconds or so then reconnect.
What I have tried:
Replacement cables
Different port on the computer
Device manager, scan for changes
Motherboard drivers
I'm really at a loss on what is going on, I'm assuming the single port from the computer can't power all the devices but the previous hub had no issues like this. I've been looking into USB PCI card but I'm unsure if this is for power or just a way to add extra ports to the computer. I've also considered buying a more expensive, reputable hub but I can't be sure the problem would go away.
This is pretty annoying and I'm lost as to how to progress from here, I appreciate this is a long winded post and perhaps missing details but any responses would be greatly appreciated.
FunsOver
- USB Headset
- USB Mouse
- USB Keyboard
The Issue:
What I have tried:
Replacement cables
Motherboard drivers
FunsOver
