[SOLVED] Planning to buy Corsair LL120 120mm 3Case Fan Pack with Lighting Node PRO
Mar 5, 2022
As the title says I am planning to buy the Corsair LL120 fans but the issue is with my motherboard and casing.
I have a very old PC. I am not quite sure if these fans connector will work with my PC.
The main issue started with my CPU Cooler fan. I have a Cooler Master Hyper 212x CPU cooler which I purchased back in 2017/2018. Recently the fans of the cooler seems to not working properly.. My CPU temp is getting really high even at idle state. So I bought a single pack Corsair LL120. I tried to replace the Hyper 212x stock fan with Corsair LL120 and had trouble installing it, so I have to take it to store tomorrow.
Also one of my fan in the front of my casing is completely not working. So I am planning to replace all the fans of my casing and the CPU cooler with Corsair LL120 but not quite sure if it will support or not.
Here are the models of my motherboard and casing as well as the CPU cooler [Link Added].
  1. Motherboard - Gigabyte Z87-HD3
  2. CPU Cooler - Cooler Master Hyper 212x
  3. Casing - NZXT H440 (Mid Tower)
