Hello! I just bought the a MSI B360-F Pro and am having issues as I can't get any display to be produced. The EZ debug led goes through the normal progression of CPU, DRAM, holds at VGA for a few seconds, then moves to boot where it just sits. Power is getting to the motherboard as all the devices (HD, cpu fan, etc) are working. However, at that point BIOS does not show up on the screen as it should. Here is what I have done so far:
Case: open air Veddha 8 gpu mining rig
Motherboard: MSI b360-F pro
CPU: I5-9400 LGA 1151
PSU: Thermaltake TR2 RX 850 W (tested working)
RAM: 16GB (8GBx2) Corsair Vengeance 3000MHz DDR4 - (CMD16GX4M2B3000C15)
GPU: EVGA GeForce GTC 1660 Ti and tried older 7950 HD radeon sapphire as well
Using PCIE 16x to 1x powered riser adapter (light on motherboard does show up) - tested 3 different risers as well
Any and all ideas are welcome...
- changed working monitors and tried multiple configurations of DVI/HDMI cables (in case it was a cable issue)
- reseated the CPU again
- Cleared CMOS
- tried 2 different working power supplys
- Trying with only one GPU before I add others to the rig just to get the OS installed
- inserted gpu directly into motherboard as opposed to using risers (same result)
- Note, I tried the HDMI/VGA for both the GPU card and the onboard motherboard.
