Question Remove volume wheel+mic from USB headset wire
Mar 5, 2019
4
Please help someone... Need to remove volume control from headset line completely cause no matter how expensive headset i'v got it still gets damaged after month or two, So I thought if i could just remove it?.. It's USB Headset 7.1 with lights.
To test if I can do this i'm gonna use cheap headset from china SADES A6
I thought to just solder wires without board (controller) but one side has more wires then other so... I wasted more than 400$ on headsets just in 6 month.
Or if you know USB headset without volume control please tell me, I was searching for one on amazon, ebay and even in local electronics store but no luck.
My victim for this test SADES A6:
Honestly, don't bother rewiring USB headsets. If you want a headset without a volume controller onboard, might want to look into headsets meant for smartphones and use an adapter for headphone and mic. You can use the onboard OS driven volume controller to manage the audio.
