rougesg
4
I have a MSI B450 Gaming Pro Carbon AC motherboard and a Corsair Carbide Series SPEC-DELTA RGB case. I hooked it up and everything works and runs fine but I can't figure out how/where to connect my led fans to on the motherboard. I've done some research and am thinking I need the corsair fan controller to get the rgb fans working but am still unsure.
Motherboard: https://www.msi.com/Motherboard/B450-GAMING-PRO-CARBON-AC
Case: https://www.corsair.com/us/en/Categ...Tower-ATX-Gaming-Case-—-Black/p/CC-9011166-WW
You need 1-TO-3 RGB SPLITTER (probably should be included with the case) connect the 3 fans and then connect it to a motherboard 12V RGB header your mobo have two of them look for JRGB1 or JRGB2 the second one is near the system_fan_2.
