Tried reinstalling drivers. Used DDU with safe mode and installed older versions. Tried taking out the CMOS battery and waited for BIOS reset. Checked thermal paste in GPU and it seems okay. Was working fine 2 days ago now fps is garbage. 100% gpu utilization but core speed is only 300 mhz. Sometimes spikes to a higher number then just drops to a steady 300 mhz even when under load. Was in the Furmark test and still 300mhz and 39-42 degrees temp. I am losing my mind trying to fix this omg
