Crashing, Freezing and getting monitor refreshes ever since installing this new GPU. It's only in GPU intensive games. I've previously had the 1080 and had no problems with it. It was a plug and play. With this 2080 I always end up crashing 10-30 minutes into the game.
I've already did a fresh install of windows. Then I did another where it deletes the WHOLE thing without a trace. I've done DDU many times. Even with it not installing Nvidia, I've lowered the clock speed by -25 and it went 2 1/2 hours of Witcher 3 Max Settting for a while but ended up crashing. I've crashed in Siege max settings, fix for that was maxing the fan speed. Haven't crashed since. I play on 1440p 144hz. I have 3 monitors. 2 of them are 1440p the other is 1080p. I've played on the 1080p before all this. Then switched 1440p same crashes. Same KernalEvent.
Tried all this with the GTX 1080 and not a single problem. I'm really hoping its something i'm doing and not having to resort to RMA.
CPU: AMD Ryzen 7 3700X
GPU: EVGA RTX 2080 BLACK
RAM: 16gb 3200mhz
Usually the error consist with this
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffc90fe59aa460
Parameter 2: fffff8032214a998
Parameter 3: 0
Parameter 4: 2ee0
OS version: 10_0_18363
Service Pack: 0_0
Product: 768_1
OS Version: 10.0.18363.2.0.0.768.101
Locale ID: 1033
Extra information about the problem
Bucket ID: LKD_0x141_Tdr:6_IMAGE_nvlddmkm.sys_Unknown
Server information: b7826963-6697-4197-8223-f275d0c83640
RAM: 16gb 3200mhz
Description
Problem signature
Code: 141
Parameter 3: 0
Parameter 4: 2ee0
Service Pack: 0_0
Product: 768_1
Locale ID: 1033
