Question RX 580 fans spinning at above 3000 rpm even while idle
5
Hi, I've recently built my first gaming pc so bear with me here. My RX 580 fans are constantly spinning above 3000 rpm the moment I press the power button. Even when the temperature is low the fans are spinning extremely fast and loud. Currently the temperature is 22C and I have 3059 rpm. Here are some readings from HWMonitor and AMD Ryzen Software.
HWMonitor
AMD Ryzen Software
Here are my specs:
CPU: Ryzen 5 2600
GPU: Sapphire Pulse RX 580 8GB
Motherboard: ASRock B450M Pro4
RAM: Corsair Vengeance LPX 3200 MHz 16 GB (2x8)
Thank you for your help in advance.
HWMonitor
AMD Ryzen Software
Here are my specs:
CPU: Ryzen 5 2600
Use the radeon software that you provided the picture from it!
Simply put the tuning control on manual and enable "Fan tuning"
over there you can set a curve or manually set the fan speed.(using curve is highly recommended)
GoodLuck
Hi, thank you for the reply! You're the FIRST to reply to my thread across 3 or 4 websites! I have a fan curve, but it does NOT work. I've attached a picture here
Do you have any other fan control software(trixx etc.) Conflicting with other?
Try to disable/uninstall others then try again.
And by the way does the fans works max when you turn on your PC?
Or they max out in specific boot sequence(after windows booted/after logo)
same problem
I recently bought RX 570 4GB
motherboard B450M PRO-VDH
when i started my pc the gpu fans are spinning at around 3000 RPM and cant control it manual with amd radeon software
Hello mate, I have a rx580 as well. First of all, if you're planning on overclocking or just monitoring, i would suggest the msi afterburner. Reset your radeon software to default and save. Never touch it again. Now for the fan problem, as i said, disable the fan control of your radeon software and only use msi afterburner to try and see. I would recommend you set a fan curve of user defined fan control using msi afterburner
Also, please exit the radeon software before using the msi afterburner or else they will conflict with each other
