My FX-8120 is running on idle at 3.8GHz with the Hyper 212 plus @ 9-15C . . . Is that safe? My room is around 76F so 24C . . . My Gaming PC is cooling my room??? How is this possible, and is it safe? Should I just be happy I have room to OC more? I realize now that 3.8GHz is a relativity weak OC or moderate OC. What should I do I guess is the question . . .
Specs:
CPU: FX-8120 @ 3.8GHz
Cooler: Hyper 212 Plus W/Push-Pull blowing up and out past two more 120mm's @ 50+/- CFM's
MoBo: MSi 990XA-GD55
Graphics: ASUS Radeon HD7850's x 2 in Crossfire.
RAM: Corsair Vengeance Black 1600 4GBx2DIMM's
HDD: Seagate Barracuda 2TB 7200RPM (Cav Black)
Case: CM HAF 912
PSU: 750W Antec Greewatts 80 Plus
Fans: Total of 6 case fans. All are Enermax 120mm Batwing Blue LED's @ 50+/- CFM's. And the four stock GPU fans on the two ASUS Rad HD7850's. And The two 120mm stock cooler master fans on the cooler rated @ 50+/- CFM's
Specs:
Case: CM HAF 912
