I have 11 router setups configured at my home as it is a multi-floor building. All my secondary routers (10 ) are configured as AP ( DHCP off and Static IP is given to each router ) which are then connected to a single Giga switch and the switch is connected to the main router. I have around 41 devices online in the network including 14 IP Cameras, 3 NVR, Smart Devices like Smart Plugs, Smart Remote, 3 Google Home Mini.
All was working very fine with no issues until from last two days I am not able to connect via any of my AP. My phone shows obtaining IP address and is stuck at it. The same with the laptop, Smart Tv's. All the devices which were even previously connected get disconnected. The problem is resolved with just a simple restart ( Not reset ) of my main router and it is resolved for another 1-3 hr and then it starts having the same problem.
The only changes to the network I made from when I started facing the problem :
1 . Added Two google home mini speaker in my network ( Total 3 speaker in my network )
2. Enabled UPnP on my main router as well as all my secondary router ( Acess Points )
I am suspecting IP Conflict but I cross-checked each device assigned IP which is separate for all 41 devices
