TH Water Cooling Club and Picture Gallery
Page 27 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Neither did I, I've been trying to mod that case panel for a long time coming but I can't figure out the lines to go with that stupid venting on the case that's at an angle. I have the advanced package which came with the unsightly shaped side window with a 200mm fan on it that was annoying and then was the silly angular venting. Also has a proprietary latch on the window panel
* when I'm done with the vintage case mod , I'll try coming up with something on it
** I cut out the lower end of the case - can't be long until I hack it in anger 😛
hey i know your probably going to laugh, i already bought it and can cancel it within ten days so i would appreciate you honest opinion .... do you think that i can OC solid with this PC
http://www.cyberpowerpc.com/saved/1ET4XC
and/or trade in the case and get upgraded GPU to 670 (or AMD if you think)
http://www.cyberpowerpc.com/saved/1ET4V1
thanks for your support!! any opinions on the build would be great!! HOW ARE the cooling systems. will they support OC at solid consumption?? plz answer
I'm Hoping I qualify for this club 😀
I7 930 @ 4.4ghz 3.7ghz IMC
12GB Mushkin redline ddr3 1600 6-8-6-21
X58A-UD3R rev 2 ( NB plate removed lowered temps 40C )
2 5870's ( 1 under water)
128GB C300, 512GB M4, 4 sammy F3 500GB raid 10
complete custom loop
Any questions feel free to ask 😀
well the idea was to get them both under water, however I bought the second 5870 second hand with the accelero on it and I found out later that it is not removable once installed 🙁
I have rewired that fan to go behind the motherboard. ( using an extension) I actually have 14 fans in this rig . 8 on the top rad, 2 on the bottom rad, rear, drive cage, and i have one sitting on the floor facing the MSI lightning, and one sitting on the top 5870 blowing at the NB. ( keeps NB around 40C idle)
my gpu idle temps are 22C ide and 40C load. cpu idles around 32C idle 2.52ghz ( and 62C after hours of gaming. 4.41ghz ( fans almost never hit full speed ( they run 50% most of the time )
my goal at this point is to sell board, cpu, and both gpus along with ram and use the cash for a new setup. looking at haswell and 8xxx ( and I need 32GB of ram ( I run out of ram with 12GB )
Thank you very much 😀 the extra 2 fans are just for NB and to increase airflow to the bottom gpu it sits 2mm above the divider so it has trouble breathing i'm sure 😛. also looking at blood red tubing instead of this uv red ( never reacted as expected under uv 🙁 ) then add red leds for lighting. the cougars on my rad looks sexy 😀
Thanks alot! I have had several ppl see my rig and ask me to build one for them. made some nice money 😉 always a conversation piece ( but no way i'm lugging it to lan parties at 100 lbs :/ ) building a SFF for lans
i like it all being internal as one unit. gotcha lol i missed the sarcasm my bad lol not looking forward to draining. as this was my first liquid setup, i did not use qdc or a drain cap 🙁 though i have to say 3 years and only distilled water and kill coil and i have no nasties 😀
Hello all,
I finally got my old tower out of the attic, and added some water cooling to it. It's a Q6600 2.4Ghz Quad core overclocked at 3.4Ghz. Idle is 34 celsius, load is 47 celsius.
I added the ThermalTake Water2.0Performer, dual pwm 120mm fans (push/pull setup) and temps are awesome now. Pushing for 3.6Ghz, as this board (P5K) as it posts and boots windows at 3.6Ghz, I just don't know the temps yet on water for that speed. Will update post once I have it all sorted out.
Here are some pics..
I know I know...Red LED Ram with Blue case fans...Working on it. 😀
3.4Ghz
3.6Ghz and stable/cool
@ Hard line - the pink tubing is distracting but I'm sure you knew that beforehand :) nice build though mate. And don't be imtimidated with modo's radbox work - those three military toggle switches are for levitating the unit while the unit is powered down - thus bringing it to eye level and an easy drain/filling procedure. Comes complete with a kinect sensor so it tilts/moves to modo's nose pitch
... :lol:
@ Sky - ah another C2Q owner, there's something about an old chip running flawlessly at those specs eyh? 😀
**Comes complete with a kinect sensor so it tilts/moves to modo's nose pitch**
The kinect sensor doubles as an automatic power on sensor for when I get home and security alarm for when we're out :)
It is not currently used to tilt the rig as I haven't got enough servo's to accommodate full range through all axis
Working on it though...
Moto
