4Ryan6 :
stickg1 :
I got my blocks in the mail today, not sure of ETA on the rest of the parts.
Ohhh, Now you're getting somewhere!
Has the bug finally bit you Nick?
Yeah for sure, lol.
Well I was watercooled for a bit. Then downgraded my system and went aircooling and reallocated the extra money elsewhere. But air cooling got boring.
The goal this time is a combination of decent performance and aesthetics in the same mid tower case, but with a strict $500 budget. With the price of the GPU block and compression fittings, I have to decided to go used on a lot of the parts to cut costs. Here is a list of stuff that I have bought already.
Koolance CPU-360 Rev 1.2
Koolance VID-AR290X
Watercool HTF2 120mm rad
Swiftech MCR220 240mm rad (possibly two, I haven't decided yet)
EK Coolstream XT 120mm rad
Swiftech MCP-355 pump
EK DDC pump top w/ 140mm tube res
All those parts are coming from 4 different people, there's a whole bunch of various fittings and adapters coming, but not enough matching ones for the whole loop. So I know there are 8x 3/8" x 1/2" Koolance Compressions and 4x 90 degree 3/8" x 1/2" Koolance Compressions, which is almost enough for my loop, I actually need 12 or 14 fittings total, I'm not sure if I can use all 4 90 degrees, I would have to get creative. 3/8" ID tubing is smaller than what I would have liked but I would blow through the budget buying fittings brand new. Also there's a whole bunch of other size and color compressions, a couple quick disconnects, and other assorted fittings. Once I have it all in front me it will be easier to determine what I can use and what I will part with.
I've spent $370 so far, I have a whole bunch of quality fans to use [I wonder where I got those
😉], lol
I just need to get the rest of my fittings, decide if I need another 240mm rad or not, and get some tubing. That should be easy enough with $130.
