TH Water Cooling Club and Picture Gallery
Page 36 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Hey, could help but notice you are a Mancunian fan. Hopefully we brought Mata :)
Anyways sorry guys for not being so active as I happened to be sick. For now It's all still raw, have to buy a new gpu probably a r9 290 or 800 series as next October I am getting a much bigger monitor.
Cooling: XSPC AX 360 push/pull config dual pump kit & Alphacool Nexxxos Monsta 480 Push with Noiseblocker 2300rpm fans(thinking of doing a custom top/shroud to do a pull config also)
CPU: i7-3960X
Video Card Sapphire R290X
Motherboard: Asus Rampage Extreme iv 2011
CPU Voltage: 1.45V
CPU Bus Speed/Multiplier: 100*48
Clock Speed: 4.8ghz
RAM: 16Gb Patriot Viper 2400mhz DDR3 11-13-13-3T
Cooling: Custom Watercooling Loop
OS:Windows 8.1 Pro 64 Bit
Nothing special but for my first loop I'm proud of it. I plan on building a very nice new system in the next 4-5 months. I wanted to get a feel for water cooling in my current system so I would feel more comfortable putting it in a brand new much more expensive rig. ( I know the 850watt psu is overkill for this rig but I needed a bigger one and plan on using the 850 in my new build)
This is my main rig, XSPC RX 760 Watercooling Loop, CPU only, ANTEC DF 85 FULL ATX chassis, ASROCK 990FX EXtreme 9, EVGA 780Ti Kinpin SLI
My build:
i7 3770k @ 4.5ghz / 1.255v
Asus ROG Maximus V Formula
16gb GSkill Trident 2400
2x EVGA GTX 670 FTW 2gb
2x Kingston Hyper X 3k 120gb in RAID 0
2x WD Black 1TB in RAID 1
Fractal Design Define XL R2
2x D5 Vario
Bitspower dual pump mod top and 240 res
XSPC Raystorm water blocks
240mm and 360mm Rads with Bitfenix Spetre Pro fans in push / pull
Ultra X4 1050 watt PSU
In the case that's riveted to the back, along with the drive cage and the 360 radiator. It's a tad smaller than the Fractal case, so I have another Define XL R2 on the way, and it'll take it's place. Ordered the case a couple days ago, and have sheets of black and red acrylic on the way from Interstate Plastics to make the front of the case.
I suggest adding a fan at the rear exhaust mount turned around as an intake to supply air to your M/B VRs and outside fresh air to the top radiator, you need to directly cool those M/B VRs or you'll shorten the life of your motherboard, they were being cooled by the stock cooling but now that's gone.
Uh, no..... My air flow is great, and I have no need for an "intake" on the back of the case. That's not a radiator in the top, they're exhaust fans.
To be honest, it wasn't quite orthoscopic surgery, but it was kind of like playing Tetris or Jenga inside the case. I spent a ton of time measuring and evaluating dimensions on everything just to make sure it would all fit. Helps when you plan a build out, detail by detail, instead of rushing around trying to fill an online shopping cart to get things delivered ASAP.
So this is what I'm working with at the moment. Thinking about adding a 140mm rad to the back exhaust and I'm replacing the corsair SP120 place holders with some koolance fans that are stronger and quieter. And then I begin the playing with peltiers phase.
