I just added some angle-fittings to help clean up my loop and figured I'd post the results. I guess this ends phase one of the build and I will be updating sometime in the spring when I get a new GPU and add that to the loop.
I'm going to add a second180 rad. The case I'm working with is very optimized for air-flow but watercooling in this thing is a bit of a challenge.
Complete Specs are as followed:
Silverstone Fortress FT01 Case
Intel i7 4790k @4.8ghz 1.36 vcore
Gigabyte Z97x Gaming 7 Motherboard
AMD Radeon HD 6950 2GB Unlocked to 6970 specs
Corsair Vengeance DDR3 Memory @1600mhz 9-9-9-27
Corsair RM750 750watt 80+Gold PSU
90GB OCZ Vertex 3 SSD
2TB WD HDD
1TB Seagate HDD
500GB HDD
Slot-Loading Blu-Ray burner
EK Supremacy Evo Nickel Plexi waterblock
180mm MagiCool Radiator
150ml Phobya Balancer Reservoir
EK DCP 4.0 pump
Primochill clear tubing 1/2ID-3/4OD
Red Mayhem dye
Silver Kill Coil plug
2x Bitspower 45degree rotary fittings
1x Bitspower 90degree dual-rotary fittings
barbed fittings everywhere else
2x 180mm Silverstone Air Penetrators in Push/Pull on intake
2x Corsair SP120 Fans (they're actually the fans that came with my old H80i) on Intake (one on rear and one at front drive cage)
1x Enermax 180mm T.P. Apollish Red LED on exhaust
The internals:
Custom CPU cutout I made with a dremel
And a picture of the front
