Hi everyone,
I found myself in a bit of a confusing situation and was wandering you you could help me out in identifying the problem.
I have recently brought a new budget PC case which came with a Fan hub. I never had a hub before so I figured why not use it.
I have an Asus Sabertooth 990fx r2.0 (old i know) which has 4pin system fans. https://www.asus.com/uk/Motherboards/SABERTOOTH_990FX_R20/
The hub itself only supports 5 3-pin fans but uses a 4-pin cable to connect to the motherboard, which makes me believe that it can control the speed of the 3pin fans. http://www.gamemax.uk/index.php/products/cases/black-hole-argb-mid-tower/
The problem is that when I connect the hub to the motherboard the fans spin and stop every few seconds as if not enough voltage is going into them. I figured maybe it's the motherboard but all the other system fan connectors behave the same way. (funny enough, when I connect the hub to only 3 of the 4 pins on the motherboard, the fans work but at full speed).
This is when I tried to connect the hub to a cpu slot and it WORKS! with all 3-pin fans speed controlled ie spinning faster when cpu gets hotter.
This made me believe that maybe the system fan connectors are faulty, but out of curiosity, I connected some 4-pin fans to to the motherboard (not cpu plug) and they all work with their speed controlled as well.
So the hub works as it should when plugged to a CPU_fan, but not when plugged into the Sys_fan, unless only connexted to 3 out of 4 pins but then only works at full speed, whereas some spare 4-pin fans work normally when connected to the Sys_fan.
So technically everything works but not where I want them to be.
Anyone have ideas what the issue is ??? Thanks!
Appologies for the over descriptive text, but this situation scrambled my brain.
