Question Thermal paste and shutdown
May 4, 2019
Hi!
just replaced my dell precision 5510 laptop's motherboard with a new one because it was said to be malfunctions by the dell lab here.
the new one started off great, but after a while (about two hours of installations and updates) it showed a blue screen of windows, said there was a problem and restarted the computer. i re-installed windows and after ten minutes or so, the fans started working really fast and loud and the computer shut down.
i restarted the computer and when it reached the windows password screen it shutdown again (same way with the fans..)
when i replaced the motherboard, i used the remaining thermal paste was on the cooling strips.
could it be that the CPU it overheating in a second and turn off?
the previous motherboard did the same and they said it was dead, could it be something else?
now the laptop works but after a while it shutdown again..
please help!
what do you suggest i need to do?
thank you!
update,
just started the computer and quickly started a temp software,
the cores temp started rising 40-41...50..55...59...fans and shutdown!
so it is definitely the cooling of the processor.
now will the thermal paste be enough?
do i need something else?
