Mr. White Reputable Aug 28, 2020 36 1 4,535 Mar 18, 2021 #1 Hi! Can those power indicator LEDs just be disabled some way, or is the only way to get rid of these putting tape over them? Is it safe to tape them? Asus Rog Strix RTX 2070 Super OC
Solution Ralston18 Mar 18, 2021 Seems to be a matter of other complaints and postings. With the problem being the overall brightness of the LED's - correct? For example: https://rog.asus.com/forum/showthread.php?107012-Disable-GPU-power-led Did not note any immediate ways to turn off or otherwise disable the LEDs. I noted a number of suggestions regarding taping and/or painting. I would do neither. Is it at all possible to just simply use something to block the line of sight to the LED's? External to the case without blocking airflows.
Ralston18 Titan Moderator Oct 11, 2014 39,433 4,382 146,290 Mar 18, 2021 Solution #2 Seems to be a matter of other complaints and postings. With the problem being the overall brightness of the LED's - correct? For example: https://rog.asus.com/forum/showthread.php?107012-Disable-GPU-power-led Did not note any immediate ways to turn off or otherwise disable the LEDs. I noted a number of suggestions regarding taping and/or painting. I would do neither. Is it at all possible to just simply use something to block the line of sight to the LED's? External to the case without blocking airflows. Upvote 0 Downvote Solution
