[SOLVED] Upgrade time, need help and suggestions.
Aug 20, 2020
Hey Tom's Hardware goers.
I'm currently in the market for a a new CPU, Mobo, Ram and GPU
I'm currently running
i5 5690k @ 4.2Ghz
Can't remember the full name of the Motherboard buts it's a Gigabyte
16Gb 2333 ram ddr3
GTX 1060
I obviously would like to upgrade to current gens but I'm having trouble deciding to go with Intel or AMD/Ryzen for the CPU/Mobo. My computer it's primary gaming with some stream services occasionally if that helps at all.
I'm not on a total tight budget but the cheaper the better would be good for recommendations.
Now with the GPU, the 1060 does cut it so that will be the last thing I upgrade but I'm thinking rather then going for the 20 series or the 30 series when it comes out, that I go and pick up a second hand 1080/TI because there pretty cheap second hand at the moment.
Thank you guys for the help ☺️
This should be good...
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i5-10600K 4.1 GHz 6-Core Processor | $294.94 @ Amazon
CPU Cooler | Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler | $48.99 @ Amazon
Motherboard | Asus TUF GAMING Z490-PLUS (WI-FI) ATX LGA1200 Motherboard | $195.62 @ Amazon
Memory | G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory | $102.99 @ Newegg
| Prices include shipping, taxes, rebates, and discounts |
| Total | $642.54
| Generated by PCPartPicker 2020-08-20 12:48 EDT-0400 |
Type|Item|Price
| Total | $642.54
Latest posts
