[SOLVED] Upgraded Parts - PC Not Turning On
Jonjonth
37
Hi there - longtime lurker infrequent poster!
I have recently managed to get my hands on a few new parts to upgrade my build, I have put these into my machine but now I'm running into quite an odd error. When the GPU is plugged in with PCI-E chords the PC does not turn on at all, when I take these wires out the PC turns on and a light even comes on the GPU (the Zotac logo). It is worth mentioning that this GPU requires 2 8-pin cords and I am using one 6+2 and a 4+4 (with a splitter).
Could of other quirks that might help:
  • Sometimes when switching on the power at the back of the case there is a small spark at the top of the motherboard (probably not a good thing...)
  • There is a red cpu light on my mobo suggesting there is a problem with this.
  • My PSU is kind of old, bronze rated and 520w (below Nvidia's recommendation) - I am 80% sure this is probably the issue but wanted to check before shelling out for a new one.
  • I've removed the CMOS battery and replaced it
  • I also put the old GPU back in and it booted - however, the screen didn't turn on...
new Parts in question:
  • Zotac RTX 3070 Twin Edge
  • AMD Radeon 5600x
  • Gigabyte B550 Aorus Pro
  • G.Skill Ripjaw 16GB DDR4 Ram Kit
Any suggestions or solutions would be greatly appreciated. Let me know any additional troubleshooting steps
I also have a local PC repair shop that I'm considering taking it along to, however, ft its most likely the PSU or something I haven't thought of I'll have a go at replacing this first.
First at all upgrade your PSU immediately to at least 650W, get one from a reliable brand and don't spend little on it as you are running high end parts.
The issue that you are having is caused by 3 reasons:
  • Your PSU is very weak for a 3070 and I'm pretty sure that it doesn't have the right cables for the GPU.
  • The 4+4 cable is for the CPU.
  • You will need to update the BIOS to run that 5600x.
This is your issue!!! There is no 4+4 plug for a GPU, that is for the motherboard. You need to use only a 6+2 cables so you will probably need to upgrade your PSU, ASAP and hope that using that cord didn't impact the GPU when running it.
Reactions: Jonjonth
Thank you, I replaced the PSU with a Corsair RM750x and Q-flashed the mobo and we're up and running!
The system is very loud under stress, so will start troubleshooting if there is any way to fix.
