Hi,
So I have been having an issue with a Microphone, mixer setup, it seems to work perfectly fine for like 15 minutes then it just makes this terrible buzzing echo kind of robotic it seems. I will post the exact models of what I have and the bottom.
The only way I can get it to work is to unplug different cords and re-plug them in, but it will only fix it for like 15 minutes. I have adjusted the gain and put it at 0, turned it all the way up, all the way down, still will happen. I have had to use it for different computers with Windows 10 and macOS, and it still happens... I have made sure there is no overlap of the cords in case its like an interference issue. I just feel like is there anything else I can try that may solve this? Or is it just a broken part, idk maybe someone has had this happen or knows why this might happen. Again it has great audio for like 15 minutes then it just suddenly goes wack. I am using the mixer for phantom power and I also have a USB adapter for it.
Here is all the stuff I am using for the setup... (I know its Amazon links but it's the easiest way to show the exact things I have)
Microphone
Mixer/Pre-amp
I guess my biggest question is there a specific reason why this happens this way and what could be causing it.
Thank you!
Microphone
Mixer/Pre-amp
Thank you!
